Old 03-19-2006, 10:14 AM
dlampe's Avatar
dlampe dlampe is offline
I had the same exact thing happen to me. I also had a complete MSD system. I tried all of the above. I even replaced the box! The lesson I learned was when you start changing parts, start with the cheeper stuff and work up. The only thing I hadn't changed was the coil. Once I did, everything was back to normal. I will bet that is the culprit! If that turns out to be okay, it is still good to have an extra lying around.
High Maintenance Racing Team
Run & Gun 2003 - 2013
