If you don't turn the engine over 5,500 rpm and the flywheel is free of even the smallest cracks, as in heat checks, you should be OK. Tapered steel flywheels--thinned at the ring gear--with small-dameter clutches don't need scattershields. Tilton and Quartermaster supply these assemblies.
Caution: This doesn't apply to plain cast-iron flywheels. Nodular ci flywheels are OK if they are in good shape.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
