Old 03-24-2006, 07:59 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Cobrabill: I see you have had personal experience with a clutch/flywheel failure, but it was with a large diameter flywheel and clutch. The HEMI GTX didn't use a small clutch or flywheel. I've also had many experiences, but mine have been with hardcore racing. Yes, I've had the disc shed its flacings during a 7,500 rpm shift, but that's not what we're talking about.
You're right, no clutch disc, pressure plate or flywheel is immune to failure, but if the right components are used--I was speaking of small-diameter clutches of under six inches and light, flex-plate style pressure plate--the chance of failure is so low it becomes insignificant providing the components are installed correctly. I am not saying this without base, having designed or cooperated on the design of all types of cars, from Indy, TransAm, Pro Stock and off road, to name a few. Check out the setup Olthoff's use in their Superformance clutch and flywheels. I have seen many nasty stuff when acting as an expert in may cases involving clutch/flywheel failures. But in all my travels within racing circles and litigations, I've never seen a clutch such as the type I have mentioned fail due to centrifugal forces.
By the way, I have a Lakewood b/housing fitted to the back of my 427 s/o.
Here's a picture of a '40 Ford Gasser with a sb Chevy in that had a flywheel come apart during an 8,000 rpm shift. This was in the early days when scattershields were not required. This is why NHRA institued the requirement.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
