Old 03-26-2006, 05:33 AM
undy's Avatar
undy undy is offline
Replace the pushrod and readjust the valves. You need the run a compression check to make sure you don't also have a bent valve before you fire it up again. The valve "kissing" the piston could bend a pushrod. You definately don't need a valve head popping off going down the road..
Too many toys?? never!
