Old 03-26-2006, 06:13 AM
Humbucker's Avatar
Humbucker Humbucker is offline
Cobra Make, Engine: Superformance #1408
Originally Posted by undy
Replace the pushrod and readjust the valves. You need the run a compression check to make sure you don't also have a bent valve before you fire it up again. The valve "kissing" the piston could bend a pushrod. You definately don't need a valve head popping off going down the road..
Would overtightening (even by only a turn) cause the valve to touch the piston? Also, why would the valve hit the piston on only one cylinder and not the others? I'm not doubting at all. I'm just trying to learn...
Thanks!
Jake - Ringgold, GA
Superformance #1408
