Old 03-26-2006, 08:03 PM
DavidNJ DavidNJ is offline
Let me throw out some 289 issues.
First, Eagle and Scat don't make 289 cranks. So to get a new bottom end it will either be custom or old Ford. Or 302/331/347.
Second, most new heads are aluminum. The original were cast iron. Low volume quality iron castings are getting harder to find. Dove is only offering aluminum now on their FE stuff (they have the original Ford molds). If you want to go aluminum, you have a wide selection. if you want to go cast iron, you don't. 1960's vintage heads are an old design with much less efficient combustion. World Windor Jr./Sr. heads are a modern design and fairly low cost. For N352 heads are a modern 10° design with peanut chambers. However they have limited intake availability and use N1 exhaust ports, which would require custom headers.
You have a lot of cam choices. However, if you want a modern technology hydraulic roller that revs to 6500-7000 you will have to watch valvetrain mass. Probably Comp Beehive springs with Ti retainers, a low inertia roller rocker, and maybe 5/16 stem valves (LS1s have 8mm, which is equivalent).
There are lots of shops that can build a 289. If there is a good local oval track shop that does winning Ford, it would probably do a good job. So would Keith Craft, probably the Cobra shop listed early in this thread, Gordon Levy, and FPS.
None of the newer 302 blocks are really any stronger. For more power you are in an aftermarket block--Ford Racing, World, Dart--with what ever emissions issues that entails.
