Old 03-27-2006, 10:49 PM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Originally Posted by cyclone427428
...I heard aluminum heads dont really work well on the street...
There's not the least bit of truth to that. My Ford 5.4 has a cast iron block and aluminum heads as do many other factory engines. If it works for the factory...
Also, because of the increased heat dissipation with aluminum heads, you can run an extra half point of compression, ie 10.5:1 instead of 10:1.
It's your engine, do what you want, but good heads and a cam to match will really wake up an engine!
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
