Old 03-28-2006, 05:41 AM
Burgs's Avatar
Burgs Burgs is offline
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
Default My Clutch is Stuck
This set up is new, and while getting ready to fire it up I was attempting to adjust the clutch, and could not get it to release. I put the rear of the car off the ramps, and up on jack stands. The rear tires spin freely in neutral. I put the TKO600 in 3rd gear, push the clutch pedal in, fork travels well, but the clutch won't release, and let the rear tires turn. So I ran the nut up on the threaded rod on the slave, and buried the fork, and the tires still will not turn. The clutch will not release.
Is it possible the disc is rusted to the flywheel? It has been a year since I put it together and has not moved since. If so any ideas on breaking it loose?
Brad
