03-28-2006, 06:29 AM
KY
So it's backwards to how it should be right? I assume the engine is running when you're trying this...
When the trans is in gear and the clutch pedal is out, the wheels will not spin.
When you push the clutch pedal in, the wheels will not spin freely.
Right?
Is the clutch disc installed with the correct side facing the flywheel?
