Old 03-28-2006, 09:55 AM
Burgs's Avatar
Burgs Burgs is offline
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
Thanks tru, but I've got a few things to try before I call in the cavalry.
I am so close to getting this thing on the road, I really do not want to tear things apart before I even get started. I will test the wiring with a battery charger before I put the car on the ground. That way I can try the starter trick, if the rock and roll fails. If that doesn't work, heII, even if it does, I'll prime the motor, put some fuel in the tank, and go for the first fire-up of the engine, (Kieth had it running already, but I haven't). After that, things will be good and ready for CNN.
