Thread: jag brakes help
Old 03-31-2006, 12:23 AM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Yes, you can get by without a booster, as long as your master cylinder is sized correctly. Can't help you much more than that, as mine uses floor-mounted pedals and a separate master cylinder for the front & rear brakes with a "balance bar" connecting them to the brake pedal to adjust front & rear brake proportioning. It's a completely different setup than a top-pedal system. You might try asking the same question on the Midstates Cobra forum, as they use the system you're interested in.
Good Luck,
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
