I had my clutch adhere to the flywheel of my 442. I tried starting the engine, in 4th gear, with the clutch pedal derpessed and with the brake on - didn't work. I tried a couple of other things as well - didn't work. What did work was to take a long standard screwdriver, and pry the clutch disc from the flywheel - was very easy. Had to have my wife hold the clutch pedal down.
If you run a scatter shield, you may have to drill a hole in the bottom of the housing for access. I just had to remove the dust cover at the bottom of the bellhousing.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
