Old 04-02-2006, 10:10 PM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Another possibility is the gasket (or "O" ring, depending on age of carb) between the metering block and carb is leaking, not allowing all of the pump shot to go through the squirters...or a bad accellerator pump/check valve.
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
