Thread: Day at drags
Old 04-03-2006, 11:52 AM
greg schroeder's Avatar
greg schroeder greg schroeder is offline
Cobra Make, Engine: Superformance, Roush 427R-095, Pro Systems carb, 2" headers, Buckshot Racefab side pipes, 10s off idle start
Originally Posted by Karl Bebout
Way to go Greg. Would you MT's not hook up for you? I've been thinking about going to them after my Drag TA's wear out. My tires wil hook up pretty well, if I get them heated. 1.7 sec 60' times are real respectable, expecially for easing it out of the gate. The track must have been not too concerned about tech that day. They kindly asked me to leave the facility after going quicker than 12.0.
I tried all sorts of tire pressures and ultimately ended up at 13 psi on the rears. My burnouts were less than stellar, but the track official gave me some good advice for the last couple runs. I was initially burning out and coasting past the start line then backing up. I guess this picks up dust and such so it still spins. I later did a little burn out and stopped before the staging area and it stuck a bit better. I'm not going to do it, but I could easily see this car on the 325/15 ET Street drag radials pulling the front end with a high rpm launch if the drive line was stronger.
The SL600 RENNTech was one of the fastest cars out there with its V12 twin turbo and mods. He did the burnout right and was running 275/17 ET Street drag radials. He was actually running 32 psi. It stuck hard with traction control off. The car has around 700 ft lbs at the wheels torque at 3000 rpm for corrected Dynodynamics numbers. Engine tourque is 910 ft lbs.
Here's a pass of the two of us when he caught me sleeping at the tree. LOL
http://www.scottsdaleexoticcarclub.c...avs.sl600.html
