Old 04-04-2006, 09:12 AM
Dinobyte's Avatar
Dinobyte Dinobyte is offline
Cobra Make, Engine: Backdraft #395 from Vintage Motorsports; Valley Ford Specialist 487 FE with a TKO600
Originally Posted by airvolts
Radiator and fans have both been changed car was getting too hot with the stock units, after upgrading both, the engine runs at 90c all day. As for the engine being too heavy, I was told since just about everything on the engine except the block was aluminum that it would not weigh much more than most stock engines. I don't profess to be a engine expert, and I just use the car to play around and enjoy, the engine combo is great and runs better than I dreamed it would.
So you had to change out the radiator and fans...hummm. I wonder if they have changed the set-up since then on the later cars. Which radiator and fan did you end up going with?
Who built your engine?
By the way, it looks great Airvolts!
Dino
