Old 04-04-2006, 08:41 PM
Tongue Pirate's Avatar
Tongue Pirate Tongue Pirate is offline
What size is your carb? The symptoms you suggest indicate that you aren't getting enough fuel down in there when you "hit it". .30may be a good starting point. My 289, when I had the holley on it, a 600 DP, ran perfect with a primary nozzle of .25
-Are all of your unused vaccum lines plugged off?
-May seem odd but did you try going down a size or two on the Primary nozzle?
-Using the carb size calculator (displacement x rpm)/3,456 if you are planning on spinning 7000rpm you could go up to an 850 carb, at 6000rpm you could run 750. For street smaller is always better & throttle response tighter.
I rebuilt a holley at one point & put it on a motor. It ran poorly for a few days on the lower end. About the third day what ever was in one of the passages must have worked it's way out cause it just all of a sudden ran perfectly. Small particlles of dirt can cause a lot of grief. The other part of this story was that this was another 600 DP & it was on a Built Big Block Chevy motor. The car had pretty tall gears so 4500 rpm was probably all I needed out of it but that carb ran so well on that motor. Much tighter than the 750 & 850 before.
Hyde D. Baker
