Thread: Steering Column
Old 04-05-2006, 07:27 PM
Three Peaks Three Peaks is offline
Could somebody explain to me this process of cutting off the shafts and adding extenders to the rack for the tie rod ends? I am just about to order the FR 1512 rack and want to know if I need to order anything else to go with it?
I would also like to see what the FR kit looks like if anyone can get that info? If not, maybe I'll call them tomorrow and see what is available in the way of info, pics, etc.....??? I may still use the VW column tube with a new shaft so I can use the VW turn signal set up I've already got. Just have to machine up a brass bushing for each end and figure out how to spline the end to fit a hub?
You know, sometimes this scratch building gets to be a lot of work!
Thanks,
Bob
