Old 04-06-2006, 08:42 AM
Zoom This's Avatar
Zoom This Zoom This is offline
I'm with rdorman here. Timing should be set at 32-34 degrees on a 351W. By pulling down the timing 10 degrees, your motor will drop in idle speed. Readjusting the idle speed by opening up the throttle blades will expose some/more of the transfer slot and may help cure you off idle stumble. Easy fix if it works.
Bill
