The Early Pinto 71-73 used the rack with 2 mounting ears, the later ones had 3 and were carried into the Mustang II from 74-78. The nylon piece you speak of is intended to be forced against the back of the rack and force it into the pinion at a predetermined constant pressure created by the spring rate, to eliminate the play you have encountered. If the nylon piece wears (becoming shorter) it will then reduce the pressure (because of a shorter combined length of spring and nylon piece) and allow the rack to be forced away from the pinion when the wheel is turned. Rebuilt racks are typically "Cores" collected from wrecking yards, that are cleaned, may have new boots installed and lubricant installed. Generally NONE of the internal parts are replaced, because it is too labor intense. Torn boots are one of the most common problems on a rack causing it to loose lubrication and without repair will accelerate the wear rate. Some of the English made racks use a brass Foot instead of nylon. The spring cannot be discarded. Be certain the installed length you ended up with will not put the rack in a bind with the pinion.
Rick
