Old 04-10-2006, 12:46 PM
SCOBRAC's Avatar
SCOBRAC SCOBRAC is offline
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
It sounds like you have an internal leak. It wouldn't happen with the 351 but my 427 had a oil passage cap come partially off creating irratic oil pressure readings... (un?)fortunately the cap was finally forced loose and I had a huge drop in oil pressure 55-60 psi to 30 psi at street cruising speed.
I never lost pressure and drove the car home (probably a bad idea) I pulled the pan to find a 7/8" freeze plug (oil plug) and clip had come out of the crank (427 steel cranks are hollow).
I decided I would at that point install a HP kit in my new oil oil pump, a blueprinted HV unit. The result should have been (I thought) about 85-90 psi cold and 65-70 hot.
What I got was 160 cold and 100 hot... Not kidding... It was obviously way too high but it's interesting. I had really good oil pressure before changing the pump. Rather than changing the pump I drained the 20/50 and put in 5/30 (both Redline synthetic). The pressure went from 160 cold / 100 hot to 100 cold / 60 hot. It will still spike if I don't warm it up properly but once warmed up it will not generally go over 100 psi and "criuses" at 75-80 psi. The internal leak it seems had been present since initial start up.
This is still a lot of pressure and may (probably will) wear my cam gear / distributor over the long run. I've spoken to a good number of sources and other engineers about my "problem" and the consensus is I don't need the pressure, although the engineer from Melling told me their HP pump was designed to run at 120 psi +. The guy who originally built my engine was big on high pressure (back in the 70's).
It has allowed me to go to the 427 S/C 0-160 oil pressure gauge...
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
