Thread: Clutch Help
Old 04-10-2006, 07:18 PM
cdnus cdnus is offline
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
Question Clutch Help
I have decided to change out my 11" hayes lever clutch to a diaphram clutch & need advice as to which manufacturers assembly to replace it with.
I have a steel wheel, Lakewood bellhousing, Top loader with a Tilton hydraulic throw out bearing.
I have already tried one manufacturer & did not have enough adjustment in the bearing to obtain the proper freeplay, the clutch fingers were to high.
I would really like to not have to go through the process of elimination or making a spacer for the transmission if there is a assembly out there with low fingers that will fit properly.
Anyone who has "been there, done that" that can help me solve this dilema would be appreciated.
Thanks
Craig
