Thread: Water in Oil
Old 04-11-2006, 08:35 AM
SCOBRAC's Avatar
SCOBRAC SCOBRAC is offline
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
What Eljaro said...
I went through this with the center oiler in the batmobile, it's pretty unlikely that any sort of condensation / humitidy would cause the change in oil texture. You sould change the oil and pull the valve covers, you will likely find there is a good deal of moisture collected in the valve cover roof.
It could be lots of things. In my case fortunately it was the water passages at the heads / intake manifold connection leaking. It turned into a little bigger project than expected when I found a huge mismatch between the standard Edelbrock F-427 and the extensively ported 427 Sideoiler heads. If it isn't obvious things get a little more involved, chasing cracks, replacing head gaskets, etc.
Good Luck,
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
