Old 04-12-2006, 07:40 AM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
My oil pressure also starts out in the 65 to 70 pound range when the engine is cold and then as the engine warms up it goes down to about 30-35 at idle (750~) but it does increase to a normal 60~ at 2000 RPM.
Perhaps, is your wet sump starved or dry (due to all the pan oil being topside) at high RPM thus causing a low oil pressure reading? Do you have enough oil in the oil pan?
How many quarts of oil do you install at a typical oil change (including the filter) My engine takes 9 quarts with the remote oil cooler and a Milodon pan. Just a thought...
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
