Old 04-12-2006, 09:47 AM
jczar jczar is offline
Cobra Make, Engine: Midstates, 351Cleveland
Default Ramps
I used 2 X 4 blocks on both ends. I drilled into the concrete floor and installed anchors. To place or remove the blocks I just use my cordless drill. Set up time for the whole ramp system is about 2 minutes. Just be sure where you want the ramp located before you drill. This location is where the ramps will be each time you set up.
John
