Old 04-12-2006, 07:16 PM
RedSnake351's Avatar
RedSnake351 RedSnake351 is offline
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
Question
Originally Posted by Morris
Dean
...We've been running our ignitions this way since 1978..... it's a good way to go because you don't have any fluctuations or movement in the timing....
Morris
I have a question along these lines. The vacuum assembly is still attached to the front of my distributor although no hose is connected. I'm sure for the same reason as you suggested while running the MSD box.
Can I remove that vacuum diaphragm assembly to make a little more room? If that's the case, will a simple plate be enough to keep out the dirt? Or will there be some other linkage attached, going into the distributor?
NEVER MIND, I took it apart and got my answer.
By the way, Morris, I also follow your build on the Gasholes.com quite often.
Ralph
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
