Old 04-14-2006, 12:30 AM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
there is no easy way around what you have to do to install the TKO. I had to remove the crossmemebr and make a new one with more forward positioned mounting holes and also had to enlarge the hole for the shifter , covering up the unused gap. No plug and play here. You may also have to trim off some parts of the TKO to make it fit. Make sure you also shim the transmission enough so you do not get too much of an angle on the driveline U-joints.
Good luck!
Nothing sounds better than a Cobra in a Tunnel !
