Old 04-14-2006, 03:31 PM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
one more tip: since the shifter turret will stick out of the transmission tunnel (at least in my Contemporary it did), you will have to make an elongated hole for it towards the rear because you have to slip the TKO straight from behind into the flywheel and through the clutch. I covered the excess hole with a removable insert covered with damping material, so whenever I remove the gearbox I just take out the insert. I had a new carpet made for the tunel to cover it all up.
Nothing sounds better than a Cobra in a Tunnel !
