Thread: Jokes
Old 04-14-2006, 04:27 PM
cobra de capell cobra de capell is offline
Banned
Cobra Make, Engine: ERA 428 FE 4-speed CR "TL" heavy spline
Cannon Balls - a History Lesson!
It was necessary to keep a good supply of cannonballs near the cannon on
war ships. But how to prevent them from rolling about the deck was the
problem.
The best storage method devised was to stack them as a square based
pyramid, with one ball on top, resting on four, resting on nine, which rested
on sixteen. Thus, a supply of 30 cannon balls could be stacked in a small
area right next to the cannon.
There was only one problem -- how to prevent the bottom layer from
sliding/rolling from under the others.
The solution was a metal plate with 16 round indentations, called a Monkey.
But if this plate was made of iron, the iron balls would quickly rust to it.
The solution to the rusting problem was to make Brass Monkeys.
Few landlubbers realize that brass contracts much more and much faster
than iron when chilled. Consequently, when the temperature dropped too far,
the brass indentations would shrink so much that the iron cannon balls would
come right off the monkey.
Thus, it was quite literally, cold enough to freeze the balls off a brass monkey.
And all this time, you thought that was a vulgar expression, didn't you?
