Old 04-15-2006, 08:55 AM
jams's Avatar
jams jams is offline
Cobra Make, Engine: B & B
There are no dumb questions.
Yes, the shock and spring were removed. Bottom of coil over mounts to original shock mount. You will probably need about an 1" spacer so it doesn't rub. I fabbed the spacer out of a piece of weightlifting bar. Just cut it to lengthe and drilled a hole in the middle. A friend with a machine shop can make it in 5 min. As far as the upper mount goes there is an upper angle iron piece with a hole in it. The upper shock stud(I think it is called) is in-line with the shock not perpendicular. Depending on your shock you might have to convert. I had to, it cost about 30 bucks. I guess I left that out of the parts list.
There is a good picture in a prior post that helped me. I will do a search if I can't find it, I have one on my Desktop computer. I am laptopping right now.
Best of luck...keep posting if you have questions.
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
