Old 04-16-2006, 12:05 AM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Originally Posted by Coralsnake
...warmed up with 14 pounds (dropping) at 800 rpms, I am concerned. I would like to see a warm idle pressure twice that. Is that wrong?...
14 lbs or better at idle should be sufficient...10 is "theoretically OK", but I personally prefer more. 25-30 lbs at idle is more than you need, but can be done using heavier oil, which isn't always good because it takes so long to get pumped through the engine on startup.
A high volume pump will not fix your problem, but IMO anything but a stock rebuild should have one...they're cheap insurance.
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
