Thread: Rear End Whine
Old 04-16-2006, 04:44 PM
blykins blykins is offline
If it's off and on like that....My guess is that your backlash/pinion depth is off a little bit.
I'd yank the diff cover off, paint the gears and see what the shape comes out to be. If you have a mag base and dial indicator, you can check the backlash as well.
There's a possibility that it could be a bearing going bad, but chances are the gear mesh is the culprit here.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
