Old 04-16-2006, 09:04 PM
Barnsnake's Avatar
Barnsnake Barnsnake is offline
Cobra Make, Engine: LoneStar LS427 , 427 Windsor
If you have 12 volts at the coil with the key turned on, you do not have a ballast resistor.
Depending upon a number of variables, 9 volts at the coil during cranking might not be unexpected. The massive load of the starter motor cranking the engine will always reduce the overall voltage available in the system. The voltage drop will be aggravated by a weak or undersized battery, small or poorly connected cables, a poor engine ground, or a "tired" starter motor. This reduction can be minimized with very large, short battery cables with heavy, fully soldered ends. You can also reduce the voltage drop by using a massive (read: heavy!) battery, so the starter uses less of the total battery capacity.
Ignition systems are designed to accommodate the reduced voltage when cranking. If you are having starting problems that you can attribute to low voltage, then the battery, cables, and starter should be checked first. Don't forget to check the battery-to-frame and frame-to-engine grounds. Paint at these connections can reduce their conductivity.
The old breaker-point systems used a ballast resistor to reduce the voltage across the points, but bypassed the resistor when cranking via the "I" post on the starter solenoid. The MSD system should already get its power directly from the positive battery cable, so using the bypass circuit wouldn't help. If the MSD box is getting its power through the ignition switch, that could be the problem.
Hope you get it worked out.
Jim
A Gnat! Quick, get a sledgehammer!
