Old 04-17-2006, 03:55 AM
mrmustang's Avatar
mrmustang mrmustang is offline
Gold Star Contributor
Jake,
You take the engine cubic inch and multiply by the maximum RPM and divide by 3456. If you have an automatic transmission you will need a vacuum sec. carb, a standard transmission can use a Double Pumper carb. For this to work, you need to get yourself up on a chassis dyno. Sure you can make a larger carb work for maximum full throttle performance, but if you want a carb that is going to handle every day driving, along with your performance needs, then your going to need to drop down in size. Again, get yourself up on a chassis dyno that offers at least HP, torque, and air/fuel ratio and you'll then see what I mean.
Now, with that said, in my case I have a 427 side oiler, solid lifters, 9:7:1 compression, and a Lunati cam, single low riser intake and originally a 780cfm Holley DB (438hp, 468ft/lbs of torque at the rear wheels). After two hours fiddling around with this car on the chassis dyno I took the advice of the owner and used the formula above, dropped down to a 600CFM Holley 04776C DP (some people called me crazy telling me I needed at least a 750DP but the vormular above does not lie) and stepped up with a larger PV and some jetting of the carb. While I lost 3hp and 7ft/lbs of torque at the rear wheels, I gained more performance out of the carb, sharper throttle response, smoother air/fuel ratio across the power band, and a driveability that I had not had before. While the numbers went slightly down in my case, I'll bet performance wise I'll actually be a few seconds faster in the 1/4 mile next time I'm at the strip. So again, when I stated above that bigger is not always better when it comes to the carb you select for your engine.
Hope you find this helpful.
Sincerely,
Bill S.
