Old 04-17-2006, 09:27 AM
maverick maverick is offline
Originally Posted by ENTDOC
I would stick with 427 CI. The whole idea behind the original motor was to rev high and quick and I think a stroker defeats that somewhat. I have stroker 427SO by the way,I wish it was standard stroke. I would also go with a hydraulic roller cam ( mild lope)and shoot for 450 hp range,you will be happier in the long run and have a more reliable engine. Again,these are all things that my motor is not and that I would change if I could. chuck
Chuck,
Your point is well taken in reference to a rebuilt, but with a blank sheet build why not take the free tq and hp available from a stroker crank, same cost?
Also agree with the hydraulic roller cam, no question the way to go.
Performance output of 600+hp @ 10.5:1 comp./ , single 850 cfm carb., idle at 850rpm, and minimal maintainence makes for a very tractable engine. Engine will make the power at or below 6200 rpm so reliablity is also a non-issue.
