Old 04-17-2006, 09:54 PM
roadrod2000's Avatar
roadrod2000 roadrod2000 is offline
Cobra Make, Engine: Unique 289 FIA HiPo 289 with Shelby dual quad intake
Corky- you said you were building a 64 289, If you use the 289 crank you would have to have special pistons to work with the canted valves of the cleveland heads. A 302 crank could use Boss 302 pistons. If you are thinking of stroking it then????????????? A Tri power set-up or even a dual quad would be less complicated. Check out this link http://www.carlsfordparts.com/main.html and look under the induction systems for complete set-ups
