Check with your engine builder on temps because he is the one to warranty the work if something goes wrong but 220 may be OK. It's seems a little on the high side to me but if it is not going above that he may tell you not to worry. You may also consider a couple of the front fans for the radiator to aid in airflow. Like stated before check everything you can before spending money
