Old 04-18-2006, 09:57 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
You have too much resistance between the alternator output and the battery. There is some kind of problem int he cable or your connection.
May I suggest you trace the output of the alternator back to the battery and see where it drops from 22 Volts to 12 Volts.
The difference is usually no more than 3 Volts from the front of the car to the rear. If there is, it is due to either too small of a wire used or a bad connection.
Just my opinion.
