Old 04-18-2006, 10:00 PM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
I bought a plate to cover the rear opening where your breather is and installed my PVC valve there. You must have a breather somewhere; I use the oil filler tube breather that fits in the intake. You also must baffle the PCV valve; I use on of these Mr Gasket #5425:
I had to drill the hole in the plate larger (I think it had a 3/8 pipe thread in it originally), and if I remember correctly, used silicone to seal everything well.
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
