Old 04-20-2006, 07:23 AM
Three Peaks Three Peaks is offline
Mine is already cut out for the sender and the pickup is part of the tank already also. I just mounted the tank low enough to clear the frame members enough for the sending unit and pick up tube to fit with about 3/4" clearance. I'm still above the level of the bottom of the frame rails by a bit.
However, if you need a stainless lid, the best place to find that stuff without risking your marital bliss is Goodwill or Salvation Army. Garage sales are good also.
Good luck on your scavenger hunt.
