Old 04-20-2006, 11:37 AM
1bad66's Avatar
1bad66 1bad66 is offline
Cobra Make, Engine: Streetbeast, 351W
How many miles on the engine? Could be rings not set well in the low compression cylinders. If you changed the carb, and it still smokes, then I am sure it is not fuel. If it idles fine, then you should not have any vacum leaks ether.
