Old 04-21-2006, 10:31 AM
sharpe 1's Avatar
sharpe 1 sharpe 1 is offline
Cobra Make, Engine: Midstates,SBF 357
You need to build a frame that will lift from inside the passanger compartment. The one midstates uses is made of metal but you can use 2"x2" or 2x4". It fits under the cowel in the front and under the lip of the body in the back.Then you can find the ballance point. If you try to pick it up thru the finder wells you run the risk of cracking the body in the door area. Good luck.
sharpe 1
