Pressure
HI Richard,
As Mike has mentioned you can taylor the action feel by changing bore sizes and pedal ratio.
I found it hard to change the ratio as things are pretty tight in there so I played arround with the bore sizes.
After 2 slave cylinders and 2 master cylinders I have a pedal that is not to light and just the right travel, I had to consider Karen as well.
The master cylinder is 3/4 and the external slave is 5/8ths.
Thanks
Phil
