Thread: Steering Column
Old 04-23-2006, 01:26 AM
KarlCSX2498's Avatar
KarlCSX2498 KarlCSX2498 is offline
Cobra Make, Engine: CSX2498 has been in our family garage since '68....Scratch built aluminum bodied 427SC Cobra, 427FE, CSX3000 chassis specs, 95% finished, only needs paint.
Default 36 spline shaft
OK, thanks. I have the 3/4" 36 spline shaft. I will double check the meas later today but that sounds like exactly what is going on. No, the chassis was off at the weld shop for the last week. That is why I could not install the steering column. I will do a final fit on the dash panel & steering column (I made the upper & lower column brackets) and take everything to the powder coater monday. I am going to have the polished hub bead blasted to match the column. They do black twice a week so it should be back in a couple days. I will post a few photos of the flaming river column install later today. Later, Karl
