Woodz428,
Bump steer affects both ends. In some ways it is more critical in the rear, since you can't steer the rear with the wheel. While excessive bump steer can make a car darty, it is also a primary contributor to roll steer. Semi-trailing arms suspensions inheritently had bad roll steer, causing trailing throttle oversteer. Modern multi-links don't, such as the Ford rears used as the basis for Superformance, JBL, Hurricane, FFR, TurnTen, etc.
However, in bump steer we are talking about changes less that .125", even less than .050", over rather large dimensions. Outside of F1, and some sports racers, measurement and adjustment is the only way to fine tune it.
Race cars have mechansims to adjust bump steer built in. Street cars don't. Cobras sort of straddle the middle. With the large number of Cobra used on track days, the low volume welding fabrication (compare say JBL to McLaren F1), and the involvement of the owners in assembly and details, I would have thought bump steer would be high on the list.
dlampe, Morris seems to be the only one who is talking about bump steer. And if reading correctly, it seems he cut and rewelded the suspension mounting points to be able to adjust it.
