Old 04-23-2006, 11:04 AM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
you should mount the turret in the most backward position possible. Even then the shifter will we more forward than with the TL and you need to enlarge the hole in the trans tunnel forward (and backwards if in your car the turret sticks out of the tunnel because you have to have space to slip the TKO spline shaft into the clutch).
good luck!
Nothing sounds better than a Cobra in a Tunnel !
