Old 04-23-2006, 04:15 PM
Roger Bolick Roger Bolick is offline
Cobra Make, Engine: Exact427
No, but likely a better solution is the LED right angle bulb thing that plugs into the existing socket. This provides a much brighter light with much less heat. Heat being a big issue, I've heard of paint/body damage from the heat of these things if for some reason the "bright" is left on (signal or brake stuck).
I would like to see info on the LED experiment. Search for someone else numbers, etc.
