Thread: Pedal Pressure
Old 04-24-2006, 08:47 PM
boxhead's Avatar
boxhead boxhead is offline
Could you maybe fit a smaller booster such as the ones fitted to the Gemini, I know these units are very small (Have fitted one to an FJ Panel van with commodore V6 engine).
I do believe you will get a lighter pedal with hydraulic than you could with cable, also the hydraulic once setup will require alot less looking after and be a less breakable assy than a cable system.
Your biggest issue with cable will be the under bonnet heat, causing lubrication issues within the cable.
Cruising in 5th
