Old 04-26-2006, 04:28 AM
cobramxz cobramxz is offline
Default Midstates Cobra With Big Block Going On Ebay 4-27-06
YOU ARE LOOKING AT A 1966 427 SHELBY COBRA REPLICA. FIBERGLASS BODY BY MID-STATES CAR WAS TITLED IN 1994. CAR IS PAINTED BLACK AND GOLD WITH RED RACING STRIPES AND WAS PAINTED WITH DUPONT PREMIER PAINT. THE MOTOR IS AN ORIGINAL EARLY 427. BLOCK CASTING # C3AE-6015 CENTER OILER, BALANCED, BLUE PRINTED, BORED AND STROKED TO 452 CUBIC INCHES. BUILT BY MILLERS PERFORMANCE, A BUILDER OF ARCA AND SPRINT CAR MOTORS. 4 CORE ALUMINUM RADIATOR WITH TWIN ELECTRIC FANS. TONY BRANDA ALUMINUM 8 QUART COBRA OIL PAN WITH WINDAGE TRAY. OIL COOLER WITH DUAL FILTERS AND RUSSELL STAINLESS-STEEL BRAIDED LINES [TOTAL 13 QUARTS SYSTEM]. ORIGINAL HIGH PERFORMANCE 427 HEADS, PORTED AND POLISHED AND C.C. STAINLESS-STEEL SWIRLED, POLISHED VALVES. DOVE HIGH PERFORMANCE ROLLER ROCKER ASSEMBLY. CRANE ROLLER CAM AND LIFTERS. OVERSIZED PUSH RODS. 2 X 4 TUNNEL WEDGE INTAKE WITH 1340 CFM HOLLEY PRO FUEL INJECTION WITH ORIGINAL FORD 427 AIR CLEANER. MSD 6AL IGNITION WITH MDS BILLIT DISTRIBUTOR. TREMEC HEAVY DUTY 5 SPEED OVER-DRIVE TRANSMISSION. LAKEWOOD BLOW-PROOF BELLHOUSING. McCLOUD HYDRAULIC THROW-OUT BEARING. FORD 9 INCH LOCKING REAR WITH 4-BAR STAINLESS-STEEL SUSPENSION. MOSIER 31 SPLINE AXLES. 4 WHEEL DISC BRAKES WITH COIL-OVER KONI SHOCKS. POWER RACK AND PINION STEERING. IT HAS LEATHER BUCKET SEATS WITH 4-POINT RACING HARNESS. COBRA STEERING WHEEL WITH TILT. COBRA FLOOR MATS. AUTO METER GAUGES--TACK, SPEEDOMETER, OIL PRESSURE, WATER TEMPERATURE, AND VOLTAGE. TILTON PEDAL ASSEMBLY. AM-FM CASSETTE WITH 2 6 X 9 SPEAKERS AND HIDDEN POWER ANTENNA. EMERGENCY KILL SWITCH IN REAR. IT HAS POLISHED STAINLESS-STEEL BUMPER QUICK JACKS. IT HAS BF GOODRICH 265 R50 15 TIRES ON 8 INCH RIMS ON THE FRONT AND 295 R50 15 TIRES ON 10 1/2 RIMS ON THE REAR. LOOK HOW THE TIRES FILL OUT THE REAR FENDER WELLS, NOT LIKE SOME THAT LOOK LIKE A PASSENGER CAR. THE WHEELS ARE HILE BRAND KNOCK-OFF 5 LUG. IT COMES WITH A TANNAU COVER AND HARD TOP WITH SIDE CURTAINS. THIS CAR DRIVES GREAT WITH THE FUEL INJECTION, JUST TURN ON THE KEY, PUSH ON THE GAS PEDAL, HIT THE STARTER AND IT IDLES. YOU CAN LUG IT DOWN THE STREET OR OPEN IT UP WITH OVER 500 HP. GOOD ON GAS IF YOU KEEP YOUR FOOT OUT OF IT. BODY AND PAINT ARE BEAUTIFUL. NO CRACKS ON THE BODY. IS ONE OF THE STRONGEST IN THE INDUSTRY. THIS IS A ONE OWNER AND WILL HATE TO SEE IT GO. WITH ONLY 3500 MILES THE ONLY THING SHOWING WEAR ARE THE REAR TIRES. THIS CAR WAS ONLY DRIVEN ON WEEKENDS AND TO SHOWS AND IS A SHOW WINNER. WORKING TWO JOBS DOESN'T ALLOW ALOT OF TIME TO ENJOY.THEIR IS ALOT OF MONEY IN THIS CAR ALMOST 20,000 IN THE MOTOR ALONE .
