Old 04-29-2006, 10:21 AM
Jack Launtz Jack Launtz is offline
Cobra Make, Engine: CSX 3020
Default Rebat Batteries
Rebat is out of business, but several companies make similar batteries. These are batteries for small aircraft, are are identified by a type # which is R35. At least two companies still make similar batteries for the replacement market. I just replaced them in CSX3020, but I don't recall the brand at the moment. There are several variations available: A style very similar with removable high caps which incorporate a ball inside which seals off the cap vent if the battery becomes inverted (God forbid). The second style is a sealed battery which has non-removable low vent caps, and a third style is a sealed battery with no apparent cap. Although the first type looks most authentic, I choose the second type because of the benefits of it being sealed. I have an old set of Rebats, and will probably pull the caps from them and glue them to the tops of the new caps. All the new batteries have colored cases--usually red or pink, and need to be painted black, but they have the correct style cases, terminals (with wing nuts), and handles. Be sure to wire the terminals in parallel (+ to +), and not in series (+ to -)--you don't want to be feeding 24V into your electrical system.
If you can't find them (do a search for R35 batteries), let me know, and I'll check the brands and let you know.
