Old 04-29-2006, 08:01 PM
poweredbyford poweredbyford is offline
Cobra Make, Engine: 1981 Aurora slabside 302
Thanks for all the replies. I've been pulling some doubles at work and the Cobra problem was put aside for awhile. I do have a regulator and reset to seven pounds, installed a new fuel filter and examined the new street avenger which is working fine. I fired her up and let here run for awhile but the sound of the pump has changed. Sounds almost like something rattling around in it and it's not as loud as it used to be. After idling for a bit I took it out and after a few minutes it cut out again and I couldn't here the pump at all when I tried to restart her. It almost seems like the pump is heating up and cutting out and after cooling begins to partially work again. I think I'm going to replace the pump and see what happens at this point. I always thought as someone mentioned that a pump just stops working period but who knows. I'll post the results of the change.
Thanks again for all your thoughts.
Dale
